Transmission drain plug washer
Sasquatch
GA
I have not changed my break-in fluids yet, but will this weekend. I see in the manual it says the transmission drain plug has a washer, but I can’t find any info on where to get one from. I have a new washer for the oil drain pan, just not the transmission. Anybody know what size or where to get one?
Try torque king. I’ve changed mine and reused the washers and have been leak free.
USMC
Naples Florida
If you can find one I believe the washer is 16 MM. I checked my local automotive stores but have not found that size.
On my oil change my washer did allow a leak.
Diesel Freak does have them.
Sasquatch
GA
I don't see anything on Diesel Freak? Got a link?
Sasquatch
GA
Do you have a link? I see a few washers on there, can't seem to find the correct one.
USMC
Naples Florida
Do you have an automatic transmission? If it is an automatic Mahindra only shows a drain plug assembly # S-S0005.PS000035
A part number for what I believe is the seal for the manual transmission is 90846. They do not say drain plug seal in the IPB.
Sasquatch
GA
Just called Torque King, they don't have those washers. He said, "google it". LOL - That's the problem, I did and still can't find it!
USMC
Naples Florida
Here is a parts breakdown if you do not have one.
If you have the old seal I would go to a local hydraulics shop.
  • 2023 ROXOR Parts Catalog Rev_001.pdf
Sasquatch
GA
Going by that diagram and the looks of the transmission drain plug, I don't believe there is a washer for it. Guess I'll find out.
USMC
Naples Florida
In the parts I see the manual transmission has loctite on the threads.
Sasquatch
GA
Just in case, I got this!!
