Tallest possible lift/tire set up to fit into a standard garage
Teagan
Howell, MI, USA
I’m a new member and about to pull the trigger on a 2020 Roxor. What’s the tallest suspension lift/level and tire set up I could run and still fit into a standard garage? My garage door opening is 82” high And I would need the 4 seat ROPS. I figure the 3”/1” lift and 33” tires I would be a little taller. I figure some of you guys gotta be pushing that limit and still fit.
Thanks in advance.
AZROX
Phoenix, AZ, USA
Hi Teagan:
You Can do the math by looking up the stock height of a ROXOR with a 4 seat ROPS. Then add the height of the lift you want. The remainder will go towards the tire radius (difference between stock and your preferred tire size).
As for stock height, that is a number you need to know anyway in any case you have a Roxor shipped (the shipper will need the dimensions and weight).
I am lifted 4 1/2" on 33s and I still fit in my garage with a 7' door.
