Battery Drain
nmwolfer
Deming, New Mexico, USA
I have a 2018 Roxor, and my battery is draining to completely dead. I thought it was the battery as it is over 3 years old, so I replaced it, 2 days later I go to start it and it is completely dead. I had a relay that seemed a little warm so I thought that may have been stuck, so I changed that and that was not the problem. Anyone else ever have a similar problem?
jerry c
Southern IL
Put a amp meter on the positive batt cable. See how much the draw is. Start pulling fuses one at a time until the draw on the batt stops. It should be easy to find after that.
Cold Steel
Montana
i have that issue with a 2022 model..
