i303
What else goes well with a Roxor other than a AR15? And what would you do in case you are 50 miles from the nearest road and happen to own a Springfield Armory Saint AR (no, that’s not a SA Saint) with a well stuck casing you can’t extract on every 59th round?
Now you know the Roxor’s dip stick will work in a pinch to pop it out because you forgot your cleaning kit. It’s on the flimsy side but it should do the job.
Do you know if your other vehicles’ dip stick will work?
And motor oil will work fine as weapon lube in a pinch.
Sh...tuff I learned as a grunt in the field.
