- Joined
- Oct 30, 2020
- Messages
- 813
- Points
- 63
- Location
- Plymouth UT, USA
- Roxor Ownership
- Roxor Owner
- Roxor #
- 6475
Has anyone gotten there roxor more level by adding front shackles. Thinking Going 1.5. Would love pictures
You've heard of climax off-road, right?Has anyone gotten there roxor more level by adding front shackles. Thinking Going 1.5. Would love pictures
when you do a shackle lift, you are changing both pinion angle and caster angle. your caster angle is way off causing the steering to be light and wondering.That was one of the first changes I made as I hated the look with the nose dropping. I used the Climax 1.5” shackles and it leveled the machine almost perfect. The only thing I didn’t like was it made the front end feel light and seems to make it wander a bit. It’s a cheap fix at about $60 and for me just temporary until I can do a mild lift with better shocks that could also bring it level. Sorry I don’t seem to have any good side shots available and I am away from the garage to take any. I will try and send some during the week if it will help.
NopeYou've heard of climax off-road, right?
So the easy level isn't worth it or how do u correct the added issuewhen you do a shackle lift, you are changing both pinion angle and caster angle. your caster angle is way off causing the steering to be light and wondering.
@Max A. Has addressed all this information, but the info is scattered. He sells climax lift shackles through diesel freak and a couple other retailers.So the easy level isn't worth it or how do u correct the added issue
You would need to install a degree shim. However when add a degree shim you also loss a little of the added lift. All in all the add a leaf is the easiest way to get some lift without changing or adding other components. Search for the thread "Lift options" good info .So the easy level isn't worth it or how do u correct the added issue
100% correct, do not use aluminum shims!That is correct. If you need to correct your caster or pinion angle you can do so with a shim. I highly suggest spending the money on steel shims. Aluminum shims deteriorate over time.
What about the 2.5 Rough country level kit?You would need to install a degree shim. However when add a degree shim you also loss a little of the added lift. All in all the add a leaf is the easiest way to get some lift without changing or adding other components. Search for the thread "Lift options" good info .
That's what I installed and have been very satisfied with it. I mainly use my Roxor around the house though.What about the 2.5 Rough country level kit?
I just ordered it. Did u do anything with shocks? Mine will just be fun with family and trail rides. Not planning on ever getting crazy.That's what I installed and have been very satisfied with it. I mainly use my Roxor around the house though.
Here's a post from when I did my lift. The shock info is in there too. RC 2.5" Leveling Kit Tips - Team ROXOR Forum - Unofficial Mahindra ROXOR Off-road Community!I just ordered it. Did u do anything with shocks? Mine will just be fun with family and trail rides. Not planning on ever getting crazy.
I did the rough country kit and it looks great. It comes with extenders for where leaf mounts to rear attachment. No shim needed.would a 2 inch shackle be too much seems like it would level out a little more and when you add the shim it would kind of cancel out ?
