front end noise
tshelton18
Rye, TX, USA
I just got a 2019 and its starting to make a rubbing grinding noise on my front end and ideas what it could be? I can hear it and fill it. after stopping or even slowing down it will stop.
Wheel bearings. take it in for warranty.
NoDak
ND
Just changed wheel bearings and it’s still making the noise and grinding. Differential? Front-end?
plumbstraight
georgia
put it up on good jacks with it stable. Run in gear and listen to where it is coming from. I would tie it down for sure. May just be a rock caught in the brakes.
NoDak
ND
The noise was coming from the right spindle bearing/brass bushing. I just didn’t go in quite deep enough on the bearing!
Also, there are grease zircs on the rear wheels that we didn’t know about!
Roxor94
Portage, MI, USA
zerks. Two on the sides that are easy to see. One on each drive shaft and the two on the rear wheels that you found.
Roxor94
Portage, MI, USA
If you use Facebook, join one of the roxor groups. There's a lot of good info there.
There’s 8 zerks. 4 spring bolts. 2 driveshaft slip joints and the 2 outer wheel bearings on rear axle.
Roxor94
Portage, MI, USA
@Partyman1971: you mention "two on the sides that are eaay to see". Where exactly are these two zirks? Is it one of these? If not, just add to this list.
I am aware of zirks at:
- 2 leaf spring bolts, front axle
- 2 leaf spring bolts, rear axle
- 2 rear axle bearings (1 left, 1 right)
- 1 drive shaft, front
- 1 drive shaft, rear
Thats all of them I believe. Sorry I wasn't accurate.
Ridem32
Terry
Where are the ones on the rear axle? Picture?
Ridem32
Terry
Anyone? Are they behind the center cap?
Ridem32
Terry
Thanks to both of y’all. Found it and greased. Took lots of grease for it to come out of fill hole. Must of been dry
