Wheel Spacers
Randy Burns
Deadwood, SD, USA
Anyone doing wheel spacers to get the tire out further to crank in the turn limiters? Who's got the best spacers?
Rolandwanders
Phoenix, AZ, USA
I put these 2 inch spacers on, gets the tire lined up perfectly when installing CJ stock fender flares.
RockTrix for Precision European - 4pc 2" Thick Wheel Spacers 5x5.5 to 5x5.5 with 1/2" Studs - for Dodge Ram 1500, Ford F100 F150 E100 E150 Bronco, Jeep CJ3 CJ5 CJ6 CJ7 Scrambler, Silver 5x139.7 https://www.amazon.com/dp/B00ATVFAOQ/ref=cm_sw_r_cp_apa_i_YEqNCbV5AD4E7
RCF
Vero Beach, FL, USA
I did two inch spacers from dirt legal worked perfect with fender flairs
Haerterich
Caledonia, IL, USA
1 1/2 Iinch wheel spacers all four, GDSMOTU, #SPCR-0007, $69.99, Amazon.
For you guys planning on different rims, i have measured the stock rims, they have a offset of "0", So adding 1 1/2 inch wheel spacers is like a rim with -38mm offset. The point is negative offset moves the tire outward, offset is measured in mm.
