DesertRox
I received this from Roxor technical support. I was curious as to what temps the light comes on and what is considered hot and what is normal operating temps. I'm using an Autometer Dashlink 2.0 to monitor things and I'm seeing temps run from 184 degrees to 204 degrees in southern Arizona in 95-105 degree ambient temps.
"HIGH COOLANT TEMPERATURE
High coolant temperature lamp in the instrument cluster will turn ON when high coolant temperature is detected
a. Lamp blinks at a coolant temperature of 110oC or 230oF
b. Lamp turn ON continuously at a coolant temperature of 120oC or 240oF
c. Lamp stops blinking and turns OFF at a coolant temperature of 105oC or 225oF
Input for this lamp is provided by the EMS ECU through CAN"
Roxor Tech Support.
Roxor Tech Support.
