- Joined
- Jun 13, 2019
- Messages
- 439
- Points
- 63
- Location
- Prescott, AZ, USA
- Roxor Ownership
- Roxor Owner
- Roxor #
- 02776
Mine makes the same noise.
Sounds like suspension to me, I would look at all bolts and make sure they are tight. I will be talking with the shop tomorrow to see what they have found on mine and let you know.
Mine did the same thing until I pumped a little grease into the front spring rear shackle bolt, there's a grease fitting on there and it went awayI am having loud popping noises with mine. Any suggestions? Power steering fluid full. No screeching at full lock. Almost sound like its coming from the steering box? This noise is while the wheels are fairly straight and when you turn the wheel slightly
Took it in and it was the power steering belt. Thanks!My Rox had the same issue. Took it back to the certified Mahindra Dealer and they tightened the power steering belt. All is well. 150 miles so far.
Owners manual says 1/2" between pulleys for deflection.Had the “squeal” on full lockAnd the other day a huge squeal do’n about 50 down the asphalt on a straight away that lasted about 10 seconds. Got home and fluid was low too. Got the fluid a couple days later and reservoir was full again?!???!!
Tightened belt and squeal gone and fluid checks normal. Had no idea how to set deflection so tried to match alternator belt. Power steering belt was much looser than alternator belt.
I think they just mean push on it with your fingers for a 1/2", that's the way I always do it. They are pretty snug though. Mine squealed real easy on full lock, I gave it a turn to 2, it will still squeal some on full lock, that to me is old school normal, but it doesn't do it as quick now.I can get 1/2” with 100# pressureafter adjust, but pretty sure I had about 1/2” prior to adjust with modest pressure. Not a mechanic so no idea what would be a reasonable pressure to check for 1/2” nor what pressure gauge is available to use.
My use to squeal at full lock, I tightened the belt. No more squeal. Easy to do. The adjustment bolt and bracket are under the pump. Easy to get to underneath the roxor. 2 minute fix.
What was the fix? Did replacing the clamp solve the issue? Mine is doing the same thing. But the issue didnt show up until winter.I have had 8 unit that had a bad clamp on the ps pump feed hoses and this cause all the fluid to leak out they all made the noise your describing make sure to check this too it’s the blue hose
Also check fluid level. Could be low or have air in the system that needs purging.
Try greasing th grease fittings on rear of spring shackles on th front especially drivers side…I am having loud popping noises with mine. Any suggestions? Power steering fluid full. No screeching at full lock. Almost sound like it’s coming from the steering box? This noise is while the wheels are fairly straight and when you turn the wheel slightly
