- Joined
- Sep 25, 2018
- Messages
- 313
- Points
- 43
- Location
- Wellston, OK, USA
- Roxor Ownership
- Roxor Owner
- Roxor #
- 000992
Good Deal!
That's the only time mine does this. Seems to me a younger generation didn't live with this commonality. The serpentine belt generation. LOLDoes it only make the noise when you can't turn the wheel any further? (steering lock stop)
yes, its the belt, pump, or low on fluid. They are picking it up and fixing it, it is not normal.Does it only make the noise when you can't turn the wheel any further? (steering lock stop)
With the factory history of not checking the fluids etc, I'd bet they are lax about greasing properly.I was just eye balling those zerk fittings today. I bet the craoking and clunking will be diminished after a few pumps on the grease gun.
You could be right but mine has practically 0 miles on it. I bought it took it home ran around for about 2 miles then called them to come to pick it up.With the factory history of not checking the fluids etc, I'd bet they are lax about greasing properly.
Im impressed they gave you such good service. I've been looking around for a dealer with a competent/reliable service department.You could be right but mine has practically 0 miles on it. I bought it took it home ran around for about 2 miles then called them to come to pick it up.
You might want to call them, they gave me a great price also.Im impressed they gave you such good service. I've been looking around for a dealer with a competent/reliable service department.
I have the managers name and number if you want it.Im impressed they gave you such good service. I've been looking around for a dealer with a competent/reliable service department.
My use to squeal at full lock, I tightened the belt. No more squeal. Easy to do. The adjustment bolt and bracket are under the pump. Easy to get to underneath the roxor. 2 minute fix.
Where in Mississippi are you? The General Manager intervened and made everything right.@Baja405 I’m glad you’ve had good a good experience with Hattiesburg Cycles. I tried to deal with them, had a totally different experience than you.
