Radio install-power wire
GPG
Fargo, ND, USA
Howdy, is there a harness tied up somewhere under the dash ready to power up a radio by chance?
Thanks
GPG
Flipping through the electrical manual, I don't see anything dedicated. I'm betting that's what the Rox Power add on it for.
None that I'm aware of. I ran my to ignition and put a fuse on it.
GPG
Fargo, ND, USA
Howdy 86
I bet that is right I did get a add on fuse block from Amazon that I will go ahead with. I see several of the in dash switch blanks have a harness hooked to the back so thought there may be a chance someone had encountered a ready to go wire for radio. thanks for the feedback I will carry on with my add on block.
Max A.
Baltimore, MD, USA
Do you have any factory switch’s like for a light bar? They will have a keyed power source.
Woodsman74881
Wellston, OK, USA
If you just want a quick hot to tie into, you can tie into your power point wire.
That's the wire I used to trip the relay to power my extra fuse block that is then powered direct from the battery. The whole thing shuts down with the key.
Woodsman74881
Wellston, OK, USA
That’s what I did with mine as well. If you don’t care about an auxiliary. That wire is easily accessible to hook up 1 item and be fused.
GPG
Fargo, ND, USA
Okay might be a dumb question here but where is the PowerPoint connection?
In days of old, before PC took over, and we were more free, we called it a cigarette lighter. ?
Trouble is that they don't work for a cigarette lighters anymore, kids don't know what they are missing. ?
