- Joined
- Oct 30, 2020
- Messages
- 853
- Points
- 63
- Location
- Plymouth UT, USA
- Roxor #
- 6475
- Roxor Ownership
- Roxor Owner
First or second oil change? or first for you? First change is to be done after the first tank of fuel, about 300 miles.I'm 200 miles away from my first oil change. I was told 51626. I've cross referenced both numbers and will personally Run a Amsoil filter.
View attachment 8464 View attachment 8465
Still on break in period. 200 away then I'm draining everything and putting in the good stuffFirst or second oil change? or first for you? First change is to be done after the first tank of fuel, about 300 miles.
Your dealer is marking up the MSRP big time. They use to be $6.99, I think they went up a bit, but they are not $25.00. Sherwood wants $12.99 and have them in stock, and I think they bump the MSRP a bit also.Just did an oil change and used the six 51324. It’s a little shorter than the Mahindra filter and only cost $10. Went with Rotella full synthetic and it was $50 for 8 quarts.
The Roxor dealer was out of oem filters and said they are $25 when in stock. They did have a service kit that had oil and a filter for $150.
There are others that will fit and probably deeper.I think Wix is going to pick up a bunch of new customers.
Thanks!
