Oil filter cross reference
Searched the forum for cross referenced oil filters, didn't find anything, so I did some research digging. Here's what I found:
I've found a lot of filters that will cross, but here's the most popular. Keep in Mind, WIX makes Napa brand filters. So the numbers are almost the same. Donaldson and CAT Filters are made by the same Caterpillar subsidiary company.
Wix- 51626
Still working on fuel filter cross referencing. This is going to take some time.
Fuel filters are a dead end.
I run Amsoil and they sent me the wix, very good product IMO.
Negative on the fuel filters. I need to update the list. Caterpillar isn't making the 9Y-4506 anymore. Not seeing an update in our system for it either. Gonna have to do it the old fashioned way with a paper book
In my daily driver it goes by percentage of oil life, in the Roxor once a year to stay on the safe side.
Col Remo
Southern Utah
Thanks. I have been considering Amsoil, but I wondered about the oil life with a lot of off road fun. Will the oil last 25K Miles in the dirt, etc. are my concerns.
I change my oil at 3000 MILES/5000 KILOMETERS, which is still anger that the owners manual says. I have 7500 miles on in almost 2 years. It's going to take me 6.5 years to get to 25,000 miles.
That's why I change it every year if I don't hit the 25k. Oil still breaks down over time. I'm very pleased with amsoil though.
Tokarev
US
Any cross reference for the copper crush washer for the drain plug?
Negative. I found that on Amazon for $8. Steep for what it is, but piecing it all together is a lot cheaper than the $181 the dealer wanted for the "kit" in a pretty box.
Tokarev
US
Have you reused the old crush washer?
BoxofRox
West Virginia
My dealer has the filters for $6.99 and the crush washers for like 99 cents. I use the Mahindra filter because it seems to be very high quality. I run T6 Rotella for oil
I have reused my crush washer, I'd say they're only good for about one reuse though. Gotta crank down on it to get it to seal, I'm not crazy about that and the possibility of stripping threads.
Tokarev
US
Anyone using the Donaldson P552518 filter?
Tokarev
US
I ordered a Donaldson P552518 off Amazon. I'll probably change oil next weekend.
Just crawling around underneath it appears to be the right length and diameter.
That will definitely be some good information. The OEM filters have disappeared. Didn't realize the virus affected them.?
I’m curious what the specs are on the oem filters {flow rate, micron, etc) compared to the will fit filters listed here.
Tokarev
US
Taken from Donaldson's website:
Attributes
Outer Diameter 3.66 inch (93 mm)
Thread Size 3/4-16 UN
Length 4.21 inch (107 mm)
Gasket OD 2.80 inch (71 mm)
Gasket ID 2.40 inch (61 mm)
Efficiency 99% 40 micron
Efficiency Test Std SAE J1858
Anti-Drainback Valve Yes
Bypass Valve Yes
Bypass Valve Setting LR 7 psi (0.5 bar)
Bypass Valve Setting HR 12 psi (0.8 bar)
Media Type Cellulose
Collapse Burst 100 psi (6.9 bar)
Type Full-Flow
Style Spin-On
Packaged Dimensions
Gross Length 3.7 IN
Gross Width 3.4 IN
Gross Height 4IN
Gross Weight 0.975 LB
Gross Volume 0.02908496 FT3
Other Information
Country of Origin Mexico
NMFC Code 069100-06
HTS Code 8421230000
The information contained herein is general in nature and may not reflect actual information
regarding the part at time of shipment. Parts may originate in more than one country ‒ the
actual country of origin and HS Code will be reflected on the Commercial Invoice(s) that
accompanies the goods.
