Diesel freak’s shocks ?
ToddBenson
Littell, WA, USA
I’m looking to replace my stock shocks because they suck so bad. But the bilstiens are so expensive. I was looking at the diesel freak website and noticed they had some replacements for the front and rear. But there wasn’t a name brand and do not have reviews on them. Has anyone installed these and if so how do you like them ? Thanks.
Do a search under shocks. There are several posts. KYB makes some for $77 a pair from shock warehouse. I went with Monroe's, big pain. Lol. I like them though. Maybe because I'm different and did my own thing. I also have a pair of shocks I can now try and return. Lol.
Just to make certain I order the right ones did you use the KYB (KG5473) shocks on all four wheels?
Couple of weeks ago, I mounted the KYB (KG5473) shocks BDRAG mentions. Whole job took less than 45 minutes. Easiest install possible.
The stock shocks came right off the studs after I removed the nuts. Since the stock shocks are not under pressure and do not expand at all, I pulled them off without any tools.
Install of the KYBs was equally easy. I left the factory straps on the KYBs when I placed a (top or bottom) bushing partially on a stud. I cut the strap and quickly pushed the second bushing on the other stud as the shock expanded. While compressing the KYB shocks by hand, I worked the bushings all the way onto the studs.
For what I am using my Roxor, the KYBs make a difference compared to stock. At about $150 - $160 they are worth it.
So AZROX, were the KYB shocks the same outside diamiter as the OEM shocks? Max A mentioned in my post about smacking the Brake Line banjo on the caliper. The picture he posted looks like OEM shock that's smashed. Lol. So as Max said, if you have adjusted the turn stops for better turning radius, check you clearances. He says I will probably be ok on mine that are 1/4 dia larger than the OEM's were. I don't plan on detaching the sway bar or doing any massive articulation like during rock crawling and have 3/4 clearance now from banjo full lock. I have never messed with the factory set turn bump stops.
I haven’t done anything with my front end. Do you think these shocks would still work?
I would also like to know if I should order 4 - (KYB KG 5473) if I have not done any modifications to the front end. Or would I need different ones in the front and back? I have been looking through a lot of old conversations on here but it seems that most people have lifted or at least leveled their roxor. I am just looking for some shocks to be noticablly better than stock but not as expensive as the Bilsteins.
I did the OTR level lift springs and used the shocks that came with them. Noticed a ride improvement after install. Then this year I started driving in some rough pastures and noticed I bottomed out a lot. Or at least felt like it. Very sharp and abrupt spring movements. Noticed it on the road as well. Seems to have gotten worse after I put a tire carrier bumper with tire on. Suppose it was way too much weight for the already weak rear factory shocks to handle. I put those kyb kg 5473 on the rear. Only $33 from rock auto. Huge improvement. Very happy with the ride now. Parts of the pasture where I was 1st gear and practically riding the clutch over spots I’m now in 1st cruising at a decent rpm. 2nd is still to fast but just short of needing to shift is about the speed I can now maintain. Appreciate the input from ya’ll.
Love rockauto I got my KYBs from them as well. Been a customer of Rock for over 10 years. My 4 kybs made my rox great.
