I am installing this The Cure! for Jeep (CJ, YJ, TJ & XJ) on a stock roxor tie rod that is popping on when you turn. I will let you know how it turns out.
It seems to be working good however I am finding that the stock front driver leaf spring makes a popping noise when turning on a several new roxors, but it does not do it with the lift springs that we are using. The cure does fit, and it eliminates the wiggle from the tie rod, but it did not fix the noise that I was chasing.
This one is on our new 6-4 kit. Works with all your factory bolts and hardware, and it includes brake lines, sway bar extensions, and extended length shocks.
We have not installed over a 33" tire so far, but the next display unit we plan on trying a 35" tire. The current price for the 6/4 lift is $1499.99 Please call us at 6015828611 or email brittney@hattiesburgcycles.com if you would like to place an order.
