What to do when engine blows up?
You’re good on the gear/tire ratio. My numbers were from when I was running 33s and 4.88s. Very similar rpm range to what you were running, I’m now on 35s. Need to step up my tune for extended road use though. I wouldn’t worry bout the tune. Is the radiator clean of mud/bugs for good airflow?
@dieselfreak whats your thoughts on these temps?
I'm running 3000 RPMS on the highway at 70mph
I’m about 2700 I think. But I’m also fully armored along with a bug heavy warn 8274 winch up front. Do you still have the factory fan? I think they’re probably unobtainium by now but the fan shroud that was offered back in the past could help your temps.
I live in the 190s all day in the city streets, I only climb up to 220s once in the highway going with traffic at 70mph. And I've only been to 230 tops a handful of times.
I'm sure the extra weight of the tires does not help, since I'm running 35s, with 5.39 gears. Plus I have a custom hot tune from Wade
Does anyone recommend a different brand then the one I'm currently running?
That's not real bad, but a little warm. If you don't have an intercooler, that will help a bunch. I sometimes get that warm bombing down the highway with 4 adults and the AC blasting, but turning that off for 30-60 seconds brings it right back down. Takes quite a while to heat soak back up. Could be your hotter tune though.
I run Zerex brand in just about everything. I kind of hot tuned my boat and temps were up, added a coolant surfactant which lowers surface tension and there was a visible difference. Changing the coolant every so often is never a bad idea (which I DEFINATELY need to do), but you could get a little bottle of that surfactant additive and see what happens as a cheap test. If temps drop a little, definitely change coolant or at least measure the mix. If there is no change, then you are not dissipating heat fast enough for one reason or another.
If I had to guess your coolant is fine, it's just all the bolt ons are generating enough heat that the radiator is at max capacity for what it can shed. Both my 82 Dodge Rampages have a larger radiator than Roxor. lol
Thank you gentlemen for your valuable insights.
This is my setup to mitigate and to get rid of the extra heat:
EGR delete
catalytic converter delete
2.5 inch dual exhaust
rx41 turbo
intercooler kit
electric fan
I find it interesting that with my tune being a little more powerful than the stage 2 tune, it trips an engine code and puts me into partial limp mode with shitty acceleration if I go over 3150 RPMs. I would have to clear the engine code before getting my full acceleration performance back. Very intriguing I must say. It even still happens with a fresh fuel filter in place. It'll say something like: fuel pressure is higher than ecm is expecting
I push my motor and haven't found the limit yet 3850 rpm tune currently and I hit it on some hill climbs. It'll take a good bit of neglect to blow one up. keep clean fuel and filter running through it and you'll be fine for many many years. the real risk is on passenger side rollovers you get a good bit of oil in the intake and it will cause a run away risk. Always restart with a t-shirt or something ready to shove in the intake, it only takes couple seconds after it starts to runaway.
You don't trip some engine code after a certain RPM? It's weird how I do. Is your fuel pump maxed out?
In case you need to go the full route, Mahindra has the engine assembly Part # 0301BAB02590N for $11,447.50.
I have attached a current parts list for the early model Roxors.
https://parts.mahindrausa.com/dealerview/Category.aspx Choose Model Search and type in Roxor. Use Chrome or Edge Browser because the web site does not work correctly in all browsers.
  • ROXOR_SPARE PARTS_ALL PARTS_04072025.pdf
WM, you got Big Balls driving the Roxor on 75. I drove military jeeps on the highway in Michigan but we were in a convoy.
I will see how my Roxor drives on a short trip on 75 between exits.
It rides fine at 75!
I still have the 3.73s so, I'm way less than 2700 at 70 MPH. In WI, so too MUCH heat is certainly NOT an issue. Too little is.. the heater can't keep up.
If anybody wants to swap their motor out for an LS, I'll give em the LS for it lol. I definitely want one of these on the stand to play with VE swapping.
Hello JROBZ,
I was just talking about the safety of driving here on 75 with the lunatics.
I have 35s like Wm and run @ 2400 rpm at 55. So, I am willing to go on the highway and test it. Wm drives there often!
AHH I-75!! Yeah was just down there lol. Not a fan of driving around in FL lol.
What to do when engine blows up?? THIS!
LOL! I know it's a tough swap, but I wanted to do this so bad on my roxor when I had it..... This is actually a CJ-7 I'm building currently, so this is NOT in a Roxor.
If its lifted I would avoid the far left lane at all cost, it'll put the roxor in a tippy like situation. The far right is the best for obvious reasons. The middle lane isn't bad
I aligned mine to a zero degree toe-in with the rear end and it was one finger driving at 70 MPH+ with 35" tires and a spring over 5" lift. Drove perfect. The right alignment does wonders on these things. But, you would't do a slalom run at that speed, so duely noted.
Well we haven't released anything yet but we have torn down 4 engines and are making a few builds. One thing we have had done was balancing the crankshafts, We were surprised how far out of balance they were. We are currently balancing the rods and pistons. We have also started on cylinder head work, we have found several area's there that will get some improvements. We will probably have more on these engines by the first part of next year. In the mean time we have 4 brand new 2.5 liter and 1 new 2.7 liter crate engines in stock. We are putting a small core charge on them so we get blown up engines back so we can build some of these performance builds. Hope this information helps.
View attachment 15230 View attachment 15231 View attachment 15232 View attachment 15233 View attachment 15234
You talkin Custom exhaust manifold that can actually breathe, with compound turbo's, fire ringed and head studs custom engines?
Would the crankshafts being out of balance cause some weird resonance in the cab at certain RPMS? I've been chasing some odd vibration around like, 1400-1800 roughly since it was new. Checked all the mounts, all seems good.
Lol, You think like we do. We already have the stud kits, We have been looking at manifold and don't really see much restriction there, we are thinking of doing an add a turbo kit just to see what the gains would be.
It definitely could. Vibrations can be hard to track down. We spend hours on the dyno trying to find them, most of the time it ends up being tires or clutch causing them, But it can be a number of things.
