Oil change
TnRox
Tennessee
How frequently should I change my oil since the last change I’ve put 1000 miles and 92 hours
Woodhound
NorthEast Pa.
Is there a compatible oil filter that can be purchased from an auto parts store?
crf88
Michigan
A lot of good info here.
Dan H.
Yuba CIty Ca.
Depending on how hard you drive and the weather, follow the manufactures recommendations. Use high quality oil. There are a set of digital download service and owners manuals for the Roxor. Download those as soon as you can. They are the complete factory repair guides.
See I for one want to run a dual Bypass kit on mine Rox. Once I find the right adaptors I want to run my oil through the full flow 20micron filter as well as the bypass filter that filters too 2 micron. I'm an Amsoil guy and would love to only change my oil when the oil sample says so when I send off to lab. Great way to see the internal workings of the engine. I have the kit just need to find the right adaptor for the engine. Once I get the right adaptor for the engine I can run Amsoil filters as the full flow and bypass filter.
I have this kit just need to figure out the adapter for the oil filter and I'll be golden. Those wix filters if you can cross-reference what all applications it will fit on I'll be able to figure out the adapter. Since we don't know what Amsoil filter it takes it hard to determine the adapter https://www.amsoil.com/p/universal-dual-remote-bypass-system-bmk23/
Wish we can find a list of all engines those work on
Oakie47p
Wv
My dealer wants 40 bucks for filter
That's ridiculous, there are posts on here with cross reference filters.
Oakie47p
Wv
Thank you,I found it. Filter six dollars change vs forty bucks. Ridiculous
mickeybobs
Hot Springs, ID, USA
I doubt that the bypass valve would ever open ,even when cold, on the 1324 filter with synthtic oil ...these filters can flow over 10gal a minute ...
Tokarev
US
Where you guys finding replacement drain plug washers?
Greg
How many quarts or liters of oil does it hold.
I am changing the filter.
