OBD2 port reading
Ckreklau
Minnesota
I have a 2024 model with the 2.7L motor. Has there been any progress on being able to read that motor? I am not looking to tune the engine. I bought a cheapo tablet with bluetooth and wifi and RAM Mount that can install apps. I tried the bluetooth adapter for the 2.5l engine and did not work. I just want a more accessible display for seeing engine temp, oil pressure, fuel, and all that without having to lean into the middle to see if there is a light on in the circle. Also an audible alert would be good for parking brake engagement.
USMC
Naples Florida
Creklau, so far, a no go on the ECU Read/Write, only at the dealer and it is proprietary. Mahindra would not tell me anything about the protocol. Wade at Diesel Freaks said they are closer but still a no go.
I spoke to a place in Italy, DFB Technology, and they are looking into it, but I have not heard from them since I sent them the information.
Some of the items you want to read do not go through the ECU, they are basic sensors on the block. You would need to switch them out and add the proper gauges on the dash.
