2023 Roxor OBD port and compatibility
right_wright
North Central WV
We have a 2023 All Weather Roxor. I would like to install a Digital Dash Display as I can not really see the stuff on the factory Round Gauge.
So, Diesel Freaks has an ODB adapter cable for 2018 to 2022 (cost $25) anybody need one? They also offer a Digital Tablet to display gauge stuff. To the best of my knowledge there currently is none available for 2023 and up
We hope to get a compatible ODB 2 diagnostic adapter that we could use Torque software to display info.
Does anyone have any experience with a 2023 and ODB usage?
Thanks!
lost1wing
Georgia, LaGrange
There are a few threads on the 2.7l ecu. Diesel Freak has been working on it. It is a tough nut to crack. We are hoping DF comes up with a solution.
Missouri Ozarks
I am sure that pretty much every one who owns a newer Roxor with the Digital Cluster would much rather have a Conventional Mechanical Speedometer and Conventional Gage's that you can see. What they currently offer leaves a lot to be desired.
If anyone from Mahindra reads posts on here. Another thing I would like to see changed is the Transfer Case Shifter. Install the original CJ Style Twin Stick Transfer Case Shift Levers, and leave the Low Range Interlock out for Low Range 2 wheel drive capability.
right_wright
North Central WV
Bob, my issue with the "digital round cluster" is the only thing I can see while driving is the speed. Our Roxor is road legal here in WV although we seldom drive on the road ways. It's primary function is to get us around our mountain property and boy can this thing climb.
I also thought it funny that you mentioned 2 stick control. During lunch today I watched a YouTube of that very topic. "MAHINDRA ROXOR TWIN STICK, 2 WHEEL DRIVE LOW" It was published by "JessyWayne" 4 years ago. 11:50 minutes long.
Back to the cluster stuff, I bought a GPS device that provides Speed, lat and long, compass direction and most importantly pitch and roll very handy for driving on our property.
Anyway thanks for the reply.
Gabe
Louisiana
The cluster gauge on the current models, I have a 2024 is really bad. At night or low light, things are fine. I sunny conditions it is pretty much useless. In particular because most of the time in those conditions, I have on sunglasses which makes it much worse! It should be recalled and replaced with something that actually works.
