Lift Shackles
Add a leafs simply make the leaf pack stiffer so the suspension does not sag as far. Not ideal for handling as you want to sit at about 50% sag for most uses. In order for the suspension to work properly it needs to move both ways. The roxor already rides stiff because of the payload capacity it is capable of.
Thanks ..Sooo ...I just put the rear CMAX straight shackels on the front ..it looks like it raised the front 3/4 of an inch from stock ,works for me . will it cause any difference in ride /steering /alignment as i use the Roxor on the street 90% of the time? Should I add any wedges, caster ,camber changes ? , also went to 235/85 16 tires on stock alloy wheels ....thanks again
Went for a drive ,drove around 50 with no road wander or floaty feeling ....so i guess im good . Dont know if i need a front end alignment ,doesnt pull but steering wheel off some ..
No wedges needed. The drag-bar can be spun out to correct the wheel. Just do not touch the tie rod. Steering wheel alignment won’t affect road going alignment. Road going alignment is not affected by these shackles.
