Electric fan install ..how difficult ?
mickeybobs
Hot Springs, ID, USA
Want to put Spal Dirt Legal/ebay electric fan on the Roxor .. so... can it be installed with radiator installed ? If not, do you have to remove the grill to get the radiator out ... As far as mounting the shroud on the radiator, some say also they bolt right up ,others say you have to modify the shroud with mounting tabs . Anyone installed one of these? thank you all .....
I wouldn't waste your money on the fan from Dirt Legal. If you want an electric fan, put together the setup yourself. Get a 16" SPAL fan, SPAL is THE BEST quality you can get. No need for a shroud unless you have an air conditioner. You can buy the wiring kit from SPAL as well, it's going to be the same as Dirt Legal, but minus their insane upcharge because they put the word "Roxor" on the kit.
