Doors & Windshield for Rocky
02/12/2026
The Windshield Frame and Inner and Outed Rubber Trim for around the glass was dropped off at Glass Plus this morning when they opened at 8:30 AM.
After getting the Windshield installed I will run the Roxor in to Anthony's Shop to have the Roll Bars tied into the YJ Windshield Frame. He has a Tubing Bender and should be able to get the roll bars sorted out.
Next is a game plan change. I have a buddy that works at a fabrication shop. I have talked with him, and what I plan to do is make a Filler Piece out of wood to go between the Fortress Roof, and the Top of the YJ Windshield filling in the approximately 4 Inch Gap between the Roof and Windshield. I should be able to work out the exact size and angles using wood for him to replicate in steel in the Fabrication Shop, complete with end caps. He Stubby Bumper-ed my 2013 MOAB JK's American Expedition Vehicles front Bumper for me a few years ago. He does great work, and is a perfectionist.
Once this is done I will be ready to work on getting the YJ's Half Doors installed on the Roxor. With luck Cody will be up for this project also.
I did manage to get the Wiper Switch popped out this morning. I am still waiting on my Rocker Switch Pro's Switches to arrive.
I did some research on the factory Light Bar Wiring today. I bought and installed the factory Light Bar Switch shortly after buying Rocky in 2024. Doing some research today I learned that the factory Light Bar Switch is wired through a Fuse Panel Relay and is ready to just plug in the (Missing Relay) to be use-able. I believe that I located the wiring to connect to the light bar under the dash.
I looked over the factory Light Bar Wiring that plugs in to the Light Bar Switch. It has FOUR Wires. It should only need TWO wires to provide Power to the Relay. Power In and Power Out to the Relay. I am wondering if the extra TWO Wires might be for back lighting when the Relay is installed in the Fuse Box. I may need to start a post on this to find out.
02/15/2026
I goofed off yesterday, and went to a Gun Show in West Plains Missouri. ZERO work on the Roxor. I did however pick up a Rivet Nut Installation Tool at Harbor Freight. I also rounded up my Electric Die Grinder, and my Cutter set that I had previously bought to work on the Roxor. Luckily the Die Grinder and cutter bits were easy to locate.
I did manage to pick up an old 40X Remington Walnut Target Rifle Gun Stock as well as an HS Tactical Gun Stock also for a short action Remington at the Gun Show. It rained all day, so the Gun Show was more enjoyable than working in the shop.
WINDSHIELD
My plan for today. After Church my plan is to enlarge the bolt holes in the Windshield Hinges. The front bolt holes are pretty good. The side bolt holes will need enlarged to get the bolts in. Two of the holes only need a little work. The holes closest to the Door Mounting Hinge are off enough that I cannot see any of the bolt hole in the Roxor. I plan to have the Windshield bolted in place when I am done today.
EDIT Windshield Installed. The bottom side bolt holes on the Roxor were too far out of Jeep Specifications to elongate the windshield hinge and get bolts installed.
WIRING
Next up for today will be splicing the wiring going back to the Rear 6 LED Flood Lights, LED Interior Light mounted on the Roll Bar, and the 12 Volt Receptacle mounted on the Bulkhead to power my Sprayer and Seeder. I will also probably run the wiring for a Front Light Bar to be installed at a later date. If you recall the reason for cutting the wiring, was that I had the wiring routed up the Drivers Side Roll Bar through a drilled hole in the Cowl. The original installation of the wiring worked fine with the Fortress Windshield which mounts in front of the Cowl. The Jeep YJ Windshield mounts on the Cowl, so the wiring needed re-routed from under the dash, to a location behind the drivers seat. I am planning on running the wiring from under the dash to behind the seat, going under the door opening. I am planning on Friction Taping the Wiring Bundle.
Now that I have determined that the Factory Roxor Light Bar Switch is Back Lit, I am planning on using it. I will need to install a 5 Pin Relay in the fuse box, and extend the factory wiring on to the back, where it can be routed back forward on the Horizontal Roll Bar to connect to the Light Bar.
Since I now have the ON/OFF Wiper Switch popped out, I can go ahead and button the Dash Panel back into place. I am still waiting on the Two Speed Windshield Wiper Rocker Switch, however I can install it later. I do need to scratch my head a little today and decide exactly how to run the wiring from the Wiper Switch to the Wiper Motor.
EDIT Completed. I ended up routing the factory YJ Windshield Wiper Wiring around the left edge of the dash using the Roxor Dash Bolts and Nylon Wire Clamps. The factory Wiring Plug ended up at the bottom edge of the dash.
ROLL BAR CONNECTION
I am off work Tuesday, and it is supposed to be a beautiful WARM Day. My game plan is to drive Rocky in to Houston, MO. to Teem Tire (Muffler, Tire and General Repair Shop) and have Anthony connect the Horizontal Roll Bars to the YJ Windshield Frame. I have new Heavy Duty End Plates (Weldable) to bolt to the Windshield Frame. Anthony has had off road Jeeps for years, he is all over fabrication work on a Jeep. He also owns a Tubing Bender to bend the roll bar ends to the correct angle. Planning to repurpose Roll Bar tubing from either the Front Roxor ROPE, or the Horizontal Roll bars from the YJ. I cut the YJ Roll Bar's off just in-case I needed the tubing.
I will close for now and probably do some planning on todays work while staying clean before Church.
Today I was working on wiring the Wiper Switch. My Rocker Switch Pro Switch has 10 Pins. The pins across from each other on each end are Hot and Ground for the Indicator Lights. I have the Lower Indicator Light jumper-ed to come on with the Ignition, like my other rocker switch's. I have the top Indicator Light wired to come on when I put the Wipers on Low.
I still need to verify the Wiper Motor Wiring. That should not be a big deal. Connect the Ground Wire, then put power to the Wiper Motor Wires, and see which wire powers up Lo and which wire powers up Hi on the motor.
Change from my above plans. I now have the guy who has fabricated parts for my Jeep Jk MOAB on board to do the fabrication work. My NEW Fabricator/Welder is scheduled to meet me Sunday after Church to weld the Roll Bar End Connector into the YJ Windshield Plate, and the Factory Horizontal ROPES. I have the roll bar connector pieces cut out and ready to weld in place. With luck they will make a good Grab Handle to assist getting in Rocky. I will also have him shorten the front of the factory ropes and cap the end to keep wasps out of it. The rear tubes are to far forward with the YJ Windshield in place. With the Front of the factory ROPES removed, the Horizontal Tubes extend past the windshield frame a small amount requiring them to be shortened probably Two Inch's on each side. I am using a 1-5/8 Fender washer with Three 1.5" Fender washers behind it with a 5/16 Bolt that will end up sticking out of the front of the Roll Bar for the Cap. The three 1.5" washers will go inside the Roll Bar as a stiffener. We will weld the bolt in place as a potential mounting location for a Roof Bracket.
After we get the Roll Bar connected up, I can work on designing the Filler Plate to go between the top of the Windshield and the Fortress Roof. The top of the Windshield Frame measures 1.5 Inches wide. My plan is to fabricate the Filler Plate out of a 2" X 4" Board first to get the angles worked out. Then have the Fabricator make one from sheet metal using my pattern. Much cheaper to work the angles out using a cheap 2x4 board.
I put the drivers side Jeep Half Door on a while ago. I will need to install Nut Zerts for the Lower Hinge. The Lower Hinge, Hinge Bolts Nuts on the Roxor are not installed in the correct location for the Jeep YJ Half Doors to mount up. I will also need to get Counter Sunk, Flat Head Torque Screws for the Windshield Hing Side Screws, or the doors will not mount up.
Looking like the door opening will need moved back approximately Three Inches or so for the doors to close. I will also need to add probably 1-1/2 Inch of filler plate under the doors.
I will also need to reroute my Wiper Motor Wiring. What I discovered was that the Jeep Door comes almost all the way to the Left Row of Switch's. I was using the Left side dash bolt's to hold the wiring clips. The wiring would end up interfering with the door installation. Better to find this out today, than after I get the Wiper Motor all wired up, then have to regroup and move it later.
With luck I will have the Wipers up and running tomorrow. I will hold off on installing the Nut Zerts, and let the Fabricator decide what we need to do.
02/21/2026 SUNDAY
The weather has cooled off again. I drove Rocky to the Sportsman's Club Saturday afternoon when the temperature warmed up to 44 degrees, and it is staged to work on today. My fabricator will also be welding up Three Viking Barricade Frames for the Club, along with welding on the Roll Bars.
I have been going over everything that I will need to do before welding on the Roll Bars this afternoon. Disconnecting the Battery is a big one. I am also considering unplugging the ECU, and possibly removing it from the vehicle. Probably using a ratchet strap of some 550 cord to pull the windshield frame back before welding. I am wondering if I should install the lower YJ Windshield Brackets that tie the Windshield Frame to the dash, just for a Fit reference. I left the Passenger Seat out, and I will need to remove the Drivers Seat, as we will be welding pretty much over it.
I did some Spring Cleaning on Rocky yesterday while the seats were out. I found my Gerber Box Knife behind the drivers seat. Unbelievable how much dust gets in the Roxor, and leaves.
I loaded the drivers side YJ Half Door in the back of Rocky for a test fit, and to get a handle on exactly what we will need to do to get the Doors installed. Just thought of something, I should probably take along the drivers side door Upper Wire Frame Section for a test fit also. That will give us a handle on what we will need to do to seal up around the door with the upper installed. The raggedy Best Top Canvas is still on the Door Upper, so we should be able to get a handle on the fit. Just thought of something else. I should load the Fortress Roof in the truck and take it along. With the roof in place we should get a better idea what we will need to do later.
Hope for the best today.
I’m looking forward to seeing the results! It will be a big improvement. I got mine out last Thursday when it was pushing 70 degrees,
I just unplugged the ECM when I welded on mine. Easier than disconnecting the batteries. On our semis we just disconnected the batteries and then weld.
I ended up just disconnecting the battery.
I discovered something I did not anticipate. The top of the YJ Windshield is not flat. It has a Bow. I have not gotten an accurate measurement, but it looks like it is approximately 3/8 - 1/2 Inch High in the center. This will require a Bow in the bottom of the filler plate.
The weather is supposed to go back warm the end of the week. So after it gets done raining, and warms up, I will bring Rocky home and get to work on the mock up of the filler plate. I will also need to take into account the Windshield to Hardtop Factory Gasket, as well as a Gasket for between the Filler Plate and the Fortress Roof. Looking at a Garage Door Seal for the Upper gasket.
02/27/2026 FRIDAY
I had the wife help me take the Fortress roof back off Thursday evening.
WINDSHIELD FILLER PANEL
I did a little measuring and I have the Filler Panel for between the Windshield Frame and the Fortress Top about ready to test fit. I used a 2x6 Board for the Filler Panel.
The Gap between the Windshield Frame and the Fortress Roof ended up being 4.5 Inches.
I have the table saw angle set on 11 degrees for the Top Filler Piece Angle intersecting the roof. I left the saw set up just in case I need to do this over.
The YJ Windshield Frame Top had a .325 Inch Crown in it.
I ended up going with 55 Inches as the total width for the Filler Panel.
Before cutting the 2x6 board, I marked the Center Line and Both Ends to be used for the Filler Panel. I then screwed a 2x4 block to each end line on the outboard sides. I made a mark at the center line approximately 3/8 Inch up from the edge, and picked up a piece of 1/2 Inch CPVC Pipe to use as a guide to mark the Crown on the board. The 3/8" crown is not a lot when marked out over 55 Inches. With a second 2x6 board to hold the CPVC up at the same height as the Filler Panel, and the 1/2 Inch CPVC against both blocks at each end of the arc. I pushed up the CPVC Tubing at the center 3/8 Inch and marked the arc formed by the bent tubing. I used a Jig Saw with a new blade to cut the Crown in the board. I will see after a while how good a job I did. A big band saw would have been a better plan for cutting the arc.
I was not impressed with what I bought for a top windshield frame gasket. I ended up getting a pair of Single Garage Door Bottom Seals to use for both the Windshield Frame as well as the Filler Panel to Roof Seal. I am much more impressed with the Garage Door Seals.
ROLL BAR WORK
All welding is completed on the roll bar sections from the B-Pillar to the Windshield Frame. Today I will start cleaning the roll bar sections back up, and get them painted Flat Black. I was hoping to get them sand blasted, however the shop that does sand blasting was doing other work for the next few days. Looking like the angle grinder with a couple wire brushed and some sanding time are on the schedule for today.
WIPERS
I still need to pop in the Two Speed Wiper Switch, and splice in a few wires. I ordered a set of new 12" YJ Wiper Blades with the windshield gaskets and trim. They look to me to be a hair too long. The passenger side blade goes up on the Rubber Trim about 6 inches up from the bottom of the glass. I will probably need to go by NAPA and get 11 inch blades for it.
I guess I better close, and get back to work.
02/26/2026 Friday Evening
FILLER PANEL
The arched cut on the bottom of the first Filler Panel had more slant to it than I originally thought. I ended up re-cutting the Filler Panel from another 2x6 board. I remarked the arc on the board as described in the post above, but this time instead of attempting to make the cut with a Jig Saw, I took the board to the Amish Cabinet & Buggy Shop in Hartshorn Missouri, and had Peter make the cut using his Band Saw. Having a Pro make the cut with the right equipment made a real difference. I then made the 10 degree cut on the top of the Filler panel using my Table Saw. After a little touch up with a Belt Sander, I wiped the board down, and put the first coat of Rustolium Flat Black Enamel on the Filler Panel. Per the Instructions I will need to let the paint on the Filler Panel dry for 24 Hours before applying a second coat of paint.
WINDSHIELD GASKET
I measured the factory Jeep screw holes retaining the Upper Window Frame Gasket. They were all spaced 6.25 Inches apart. I nailed the Garage Door Lower Seal that I am using for the Upper Windshield Frame Gasket to a 1x6 board to keep it straight and flat. I then measured the hole locations, and punched them with small leather punch. I then screwed the gasket in place with new Lath Screws. This went smoother than anticipated.
B PILLAR to WINDSHIELD FRAME ROLL BARS
I used my Angle Grinder with a Wire Brush to clean up the blistered paint on the Roll Bars after they were welded together. I then wiped them down with Alcohol on a Shop Towel. I then painted them with Rustolium 2X Flat Black Spray Paint. They look pretty good. The Extension connecting the Roxor factory Roll Bar to the YJ Windshield will make a good Grab Handle for getting in and out of the Roxor.
The Roll Bar's and the Filler Panel are both hanging off the Bale Forks on the tractor in the shop drying. I have a Short Course Rifle Match in the morning. By the time the Match gets completed, and I get everything put away at the Range, It will be 2 PM of so before I can get back on painting the parts, unless I paint them in the morning before I head to the Range. (Better Plan) The Weatherman is predicting Inches of Rain starting Sunday. I will get Rocky back in the shop out of the weather tomorrow. When the paint drys, I will start reassembly. I have new 1/2 wide X 9/16 thick Weather Seal to go on top of the Roll Bars for the Fortress Top to rest on. The original weather seal was One Inch Wide. I plan to double up the seal material so that it is One Inch Wide. No more dragging the Fortress Top off and on over the roll bars. With new Weather Seal Material I will need to carefully set the top back on the roll bars. The paint on the drivers side of the Windshield Frame got blistered a little welding the Roll Bar End Plate in place. Good thing that I had saved just a little of the Spanish Moss Paint for touch up, I ended up needing it.
Can’t wait to see it. I also wonder if a windshield header channel like for a bikini top or soft top would have helped bridge the gap while maintaining that arch needed to fit the windshield frame. Plus you get the benefit of factory attachment to the frame. I have one off a TJ soft top hanging in my shed. I put it up once trying to come with an idea to use it but it didn’t mesh very well with the OTR windshield frame if memory is right. But a Jeep windshield frame would be spot on.
The Filler Panel ended up being 4-1/8 Inch's high on the end's.
So far I have not done a Roof Test Fit with the Filler Panel in place.
I am hoping to do that today after Church. With luck it will be a completed installation.
I installed the Side Roll Bars yesterday. They sure look a lot better with the blistered paint removed, and fresh paint on them. We took Rocky out for a drive on the Deer Lease after getting the Roxor roll bars back on, and getting the passenger seat reinstalled. The angled roll bar connection to the YJ Windshield Frame makes a really good Grab Handle getting in and out. I also got the YJ Sun Visors installed on the windshield frame. Big improvement over the Roll Bar Mounted sun visors for a side by side that I have been using the last couple years.
I still need to finish removing the old Insulation from the top of the B Pillar, and then install new Foam Insulation. The Foam Insulation between the roof and the roll bar is probably to help with noise more than anything. I brought the Filler Panel in the house yesterday evening to dry better. The Weatherman has lots of rain in the forecast the next few days. I was really surprised that it did not rain overnight. At this time the Sun is still shining out side.
02/05/2026 Thursday
A brake in the rain for today, but a little damp and cool.
I had previously installed my Garage Door Seal on the top of the YJ Windshield frame. I used Lath Screws to hold the seal in place. The screws all went back in the factory holes. I mounted the seal with the tall lip up on the back wrapping up the windshield frame's lip. It Looks like a factory seal for the windshield. It is much better than the Factory Seal in my application.
Monday after work I finished cleaning off the B Pillar Foam Insulation, and I installed new Foam Insulation on the B-Pillar and the roll bars going to the front that the Fortress Top sets on. I installed the Second Garage Door Seal on top of the Windshield Filler Plate. I installed this Seal with the tall Lip up and to the back, so it is against the roof. I also screwed it in place to the Wooden Filler Plate with lath screws.
I had my brother come over after work, and the two of us and my wife set the Fortress Roof back in place. We lifted the front of the roof up a little and placed the Filler Plate in place. I then installed the two front 3/8 Inch Roof Bolts. The Fortress top was originally mounted with an adjustable bracket on the front that attached to the Bolts holding the front ROPE's together. After the welding on the roll bars was completed last week we drilled the front of the roll bars for a 3/8 Inch bolt to go down through the roof and roll bars to hold the roof in place. No need for adjust ability now. The roof bolts went back in place with no issues. I did not tighten any thing down at that time.
FILLER PLATE
The filler plate was a very good fit the second try after having the Amish Craftsman cut the Arc with his Band saw. I did have to do just a little belt sanding in the center. I am sure this was due to my marking the line a hair low, and not his following the line that I had marked. I was pretty impressed that everything came out as good a fit as it did. My original plan was to give the Wooden "Pattern" Filler Plate to my shop guy to make a metal Filler Plate. I now plan to just use the wood plate, I am sure that it will last for several years. The Fortress Roof front lip covers it very well to keep it out of the weather when parked.
THURSDAY'S PROJECT
No rain today, but damp and cool outside. I plan to tighten down the Roof Mounting Bolts, and then mark the top of the roof on each side, locating the Filler Plate below. The plan is to mark a Center Line on the roof to drill the roof and then install screws with rubber gaskets under the Stainless Steel flat washers to secure the Filler Plate to the roof. The Filler Plate is sandwiched in pretty tight, however I would feel better with a few screws holding it in place.
I also need to finish up wiring the Wiper Motor, and pop the switch in place, after I make sure the wiper motor is good. I am sure that it is the 1988 original to the windshield. With any luck it will all function just fine.
I also have Two additional Harbor Freight 6 LED Flood Lights for the rear dovetail. I mounted a single in the center of the roof dovetail when I bought Rocky almost two years ago. It is pointed right at the spare tire that I installed after the light was installed. It does a great job lighting up the bed. The other two flood lights will go on each outboard side to light up behind the vehicle.
I also need to get a flat piece cut the size of my Vehicle Log Book to mount to the Filler Plate to hold the Log Book. I hold the Log Book in place with a big office style paper squeeze clamp. The factory YJ Sun Visor is too narrow to hold the log book. FYI I keep my Insurance Card in the log book, along with logging all Work Performed, Tire Changes, Oil Changes, ect.
Then I will need to get all of my recovery equipment reinstalled under the seats.
I am hoping to get this part finished up today. I am stalling in hopes that it will start warming up some.
  • Like
Reactions: Ted
