JB2133
I have three wiring harnesses (will be using rocker switches - rear bumper lights, rock lights, interior dome) that each come with the corresponding in line fuse and I’m wondering what options others have used for hot/ground hookups. Can you pigtail the hot pole from the battery to make it easier to get wires out of the way?
Direct end metal loop over battery terminals is obviously the easiest (I only know this way, but I would like to do something cleaner than having three loops over the posts). I am currently installing the XTC auto cancel signal kit so I know the roxpower fuse box is in the driver side footwell, and the main fuse box is on the drivers side of the engine bay. Any recommendations?
Side note- Im completely clueless on where all these grommets are. Instructions make it seem like its easy to get wiring into the cab, but it looks like they feed into the area under the factory center console and/or the tar tape covered holes go into the lockboxes which seem useless. I’d prefer not to have to punch through the main boot on the frontside of the cabin.
