Tire Wheel Combo
Baja405
Madison, MS, USA
What is the largest tire wheel combo I can put on my 2018 LE without having to modify or lift the suspension?
Delta, PA, USA
Not sure of how tall but i bought 15×8 5×5.5 with 3.75" backspace they stand out about 1" past body
Delta, PA, USA
Well 15" tires are alot cheaper and i have $600 in 5 new tires and wheels they are 235. Look on ebay at forceum mud tires 4 new will cost $330. Plus you can sell your old ones and walk away even or with a couple bens in your pocket
Haerterich
Caledonia, IL, USA
For you guys planning on different rims, i have measured the stock rims, they have a offset of "0", So adding 1 1/2 inch wheel spacers is like a rim with -38mm offset. The point is negative offset moves the tire outward, offset is measured in mm. Bach spacing is ok to use but different rims can have different offset but the same back spacing. So if you find a rim you like and it list the offset, its the best way to understand how much different the tire will sit in/out.
Baja405
Madison, MS, USA
Great information, thanks
i303
Arizona
I'm getting old school steel wheels when I get a chance. Prefer to stay with 16 in. but may get the 15.
Ragnar RoxHard
The AZ
For the standard tire set would you go with goodyear steel or BFG Aluminum?
