Jesse Torque King 4x4
We are FINALLY in the final stages of designing a rear PTO output for the transfer case. Hoping to have something by end of month but might be pushing past that a bit with the finite details. We are currently fitting a prototype housing, then will move on to the output shaft.
Won't get too far into specifics yet but I will say this is a "finish to suit your needs" kit. Some fab will be required on your part for shifting, and this is designed where you will need to either mount a hydraulic pump to the round cross member over rear axle, or mount a carrier bearing for a direct shaft out the rear. If it was mine, I'd do the hydraulic pump and use a power pack for bumper mounted PTO shaft so there was still other hydraulic control options.
Due to weight and ground clearance, I have designed this to NOT direct-mount a pump to the PTO.
We are also hoping to include a digital RPM indicator. Shifting could be done by cable, or we have factory transfer case shift parts to start as a base for rod-shifted applications. Engine RPM would currently need to be done by cable or a steady foot, however another project has opened the doors for a possible future electronic control.
As power is transmitted through the transmission, output RPM (and direction) will vary depending on gear selection. You would be responsible for gathering correct driven implement operation RPM vs desired ground speed vs PTO output RPM. I am only supplying the main apparatus to make an accessory drive possible.
Not everyone will see this right away but I would like to get a rough count on who is interested. I anticipate a rough cost to be around $1500 +/- USD, and will make a install video for correct setup. All custom parts are Made in USA, and we will stock service and replacement parts. Note that even though the price would be significantly lower, I do not desire to offshore production of custom parts.
I welcome any suggestions or input you folks may have on this.
