Question on floor drain plugs
These have worked well for me (so far). The 1 inch (25 mm) fit nicely into the drain plugs onto the floor. However, the holes in the under seat box have varying sizes. So the 10mm and 18 mm have worked to cover the holes where the foil backed patches have come off. I have the cab so I don't necessarily need the holes to drain the cab. I do get a fair amount of mud, splash, or especially moon dust that come up through the holes so I would rather have them plugged then unplugged. Besides, in the event I need to drain the floors during a washing or what not, just take them out, let it drain and put them back in. Hope this helps.
Hole plugs.png 20260307_153821.jpg 20260307_154008.jpg 20260307_153124.jpg 20260307_153255.jpg
Ok ChukarHunt, that is too much Common Sense that you are eleuding to!
View attachment 15381 View attachment 15382 View attachment 15383 View attachment 15384 View attachment 15385
Thanks. I think I’ll order a set. I hadn’t even thought about inside the seat storage.
Putting plugs in the drain holes is counter productive if you have water standing in the cab already.
I need to drill holes. I also don't want water coming in during a water crossing, so that is what the rubber plugs are for.
It sits in the polebarn quite a bit. Dirt dobbers love little holes to climb into. The plugs will keep them out as well.
My Jeep TJ had rubber floor plugs for the floor drains. My Roxor never had plugs and this winter I’ve had so much cold and snow come in through the drains I decided to plug them. I could do the work myself and measure and search but thought someone might have the answer off the top of their head. Are there OEM floor plugs from Mahindra. If so does anyone have a part number. If not has anyone found a decent rubber plug that will fit?
Thanks a million. I appreciate you letting me slack off and beg you guys for an answer.
Amazon is where I got mine
