Perplexed drivers side sag
So my 2020 sits 3/4 inch higher on the passenger side than the drivers side. The axles are even all the way around. It's the suspension and above. I have a head scratcher?? Someone educated me on leaf springs, so I loosed the rear shackle bolts and flexed the heck out of the suspension and got it alot closer. Makes me wonder why the rear and front shackles don't also have zerks to add grease
I have aftermarket springs all the way around. I’m still higher on the passenger side. If memory is correct it’s about 1/4-1/2”. Maybe we should measure more Roxors. I bet there’s a quality control issue concerning spring mounts. Or maybe it’s intentionaly higher to compensate for drivers weight except in the states the driver is on the other side and thus the drivers side lean.
Paulson
Se Arizona
i noticed that with mine. it was the body mount bushings were really tight on the drivers side. and louse on the passenger side.
