Parking brake light stays lit
So went out playing and now my light stays on or flickers on and off when driving? I'm thinking needs adjustment??
Any thoughts
JFro
Central Florida
Same issue here.
Added the 5.5” lift and now the brake light stays on.
- checked the tension on the cable and it’s not crazy tight.
- brake fluid reservoir has the correct amount of fluid.
Anywhere else I can check?
Air in lines did u bleed your brakes after you installed longer lines. My issue was leaky line
Woodsman74881
Wellston, OK, USA
More likely than not, it is the cable pulling on the switch. My Roxor isn’t lifted. Cable is pretty slack. Start pulling the parking brake handle and on second click, parking light comes on.
