Need help! 12 volt port on dash doesn’t work!
InfRoxor
New York
Hi fellow Roxor enthusiast! My 12 volt port on dash doesn’t work. I have XTC turn signal kit and trailer wire. It works great. I’ve checked the following;
1. Main Fuse box under hood.
2. Passenger dash fuse box.
3. Drivers side dash fuse box.
I found;
1. 1 fuse was out under the drivers dash.
2. Main fuse box had 1 fuse out and 4 extra fuses that showed no power going to them. The schematic shows no fuses in those slots. I replaced all 4 extra fuses and tested and no power was going to them so I pulled them.
Thank you for any fixes you may know of.
DrunkenSlug
NC
I found;
Hey dude, kind of dumb but I had something similar happen after having my dash apart. If you follow the red wire back from the 12v (back side of dash), you'll find a (I assume thats what it was, mine disintegrated) fuse holder. Pretty sure it's already a fused connection, no idea why it was there. Mines a '25 for reference, your mileage might vary. Fix was simple after finding that, just reattach the wires.
