Max Travel YJ spring kit install
Rxr-Ron
Little Rock, AR
These particular 35s measure 34.25" diameter. Probably could run 37s
View attachment 8893View attachment 8894
Need 2xbanjos, 2x90s, and 3x brake lines. Not pictured here (low quality picture below) is a straight bulkhead fitting needed for the rear brake line. The roxor uses -3AN fittings.
Shout out to @Colderweather86 for figuring out the lines and fittings.
As far as I can tell I'm the only one that extended the rear line other than @Max A. Who redid everything south of the power train.
11 13 13 3/8 11/16 wrenches needed for the brake lines.
At less than 300 miles my stock brake lines had been rubbed down to the braided steel. The rubber coating was completely gone where they contacted the tires.
At this time I'm waiting on a -3an coupler to fit the extended rear line into the T fitting.
View attachment 8871 View attachment 8893 View attachment 8894 View attachment 8895 View attachment 8896 View attachment 8897 View attachment 8898 View attachment 8963 View attachment 8964 View attachment 8969
Thanks for posting the brake line part numbers! Got 'em ordered for my Max-A LTK currently being installed. Cheers!
