- Joined
- Oct 30, 2020
- Messages
- 809
- Points
- 63
- Location
- Plymouth UT, USA
- Roxor Ownership
- Roxor Owner
- Roxor #
- 6475
How often do you grease everything? I did mine a few months ago and feel like it's due again with all the extra noises
The owners manual says every 400 miles I believe, I try to do it every 500 give or takeHow often do you grease everything? I did mine a few months ago and feel like it's due again with all the extra noises
I’m sure you know, but there is a grease point on the axle housing on the outer end of the rear axle on each sideThat's real for sure. It's so simple so why not. After I did it it sure made things quiet
Thanks AZROX!@Willys: there is a link to the entire servicei and repair manual somewhere on this forum. That manual will tell you more than you will likely ever need ro know about the Roxor.
There are also already a number of posts from a couple of years back about the grease points.
Grease points: leaf springs front (2), front and rear drive shafts (1 each), rear axles (one left, one right) towards the drum brakes. There is a 1/16 hole on top of the axle above the zirk fitting. Pump grease until a fine line of grease will come out of that small hole and you know the wheel bearings are greased.
There is also another link to the electrical trial wiring diagram.
where did you get an owners manual.The owners manual says every 400 miles I believe, I try to do it every 500 give or take
My dealer told me they have no owner manuals.
My 2022 does not come with one.
The on the Rox heavy duty steering kit has greasable ends. Great upgradeWish it had more fittings. Like for the steering components, I will eventually upgrade them to be able to grease them. Also wish the U joints had them.
I've seen them at an affordable price.The on the Rox heavy duty steering kit has greasable ends. Great upgrade
Where did you see them other than the on the rox site?I've seen them at an affordable price.
