Mahindra has done some good corporate deals as mentioned here and in other threads. I'd be curious to see what the corporate vs private sales ratio is. I bet they are pretty close. As mentioned, coal mines and railroads are making good use of the Roxor and its a perfect fit as the Roxor never leaves the property. I would think forestry could benefit as well. Here in the flat lands, the farmers use pickup trucks to service their property. When you got corn as far as the eye can see, you don't tear through it, you go around.. on road. Ill see a UTV on smaller acreage from time to time for sure... Absolutely. Also, at some point the private market will saturate because these things will just plain last forever. The private market for the Roxor is also limited by its off road use only issues.
Lets be clear and honest, you may have a licenses on your Roxor in whatever (any) state you live, but that's not because you can, its because to tricked the system. God willing we all drive safely and never end up in a deadly crash on the road. Should that unfortunate accident happen to you, and even worse, is caused by you and your Roxor on road, you will most likely lose in court and Mahindra wont show up to defend the vehicle. Not because you of what you did or didn't do on the road, but because you were operating a vehicle manufactured for off road use only. I think if it like this, my surgeon uses medical grade power tool to crack the chest. Would you want him using a cheaper Milwaukee Sawzall instead simply because he got a certification by gaming the system? I know... I know... bad example, but you get the point.
So let the flames begin....
