Help!!!
Jagladwell91
Poplar Bluff
Own a 2019 mahindra roxor around 3000miles. Got it close to water and buried it in the sand and water up to the bottom of the doors. Had to replace the starter, once got it going it wouldn’t shift past 2nd gear. Sent to a shop where ecu was flashed and did not fix the problem. Been to two transmission shops both stating the transmission looked brand new, no water or anything had gotten in it. That shop was unable to fix so they sent it to another shop that found some chaffed wiring, whole new wiring harness put on still doing the same thing. Also mahindra stated they needed to hook up to the transmission and clear any codes but then mahindra also stated they don’t sell the hookup to clear the codes and no transmission shops around can access that! Help!
