First lube job
billyg
iron station nc
I found it amazing how easy it was to change the differential and transmission fluids. Then came the transfer case what's this? Different plugs! Why not use all the same plugs for all drain and fill spots. Finding a square post socket was interesting. Not exactly a single off the shelf item unless you want to buy it in a set. Anyway I did get the job done . Has any one found metal slivers attached to the magnets? It doesn't look like any gear chips but casing residue. The outside of the transfer cast was oily as if it had been leaking. Not a pretty sight.
Scatman
Lacombe
Hey,billy
I just bought a used roxor. Tomorrow I’m changing all the fluids. That is strange to have the square in the drain of the transfer case. I hope to find a mm sq socket to fit it. mine is oily in that area also and I had a 10 mm hex to fit the fill plug. Pinky couldn’t find oil. I’m an old Harley rider. If it’s not leaking oil, it’s out of oil. Lol.
Y’all are over thinking it. A wrench works just fine. I think I even used a crescent.
Scatman
Lacombe
The fill for The transfer is easy a 9/16 open end fits perfectly. The drain is a recessed square, female.
billyg
iron station nc
All I was saying is from the beginning of the Roxor or what ever they called it in India changing the style of drain and fill plug for one part of an 8 part set would serve no purpose other than give someone a headache. The fill plug was not the issue the drain plug was. I made my socket using a common male hex socket and a grinder. Much faster than trying to find something in cyber space.
Joxor889
USA
What is the bit needed for the drain bolt on the transmission and diffs?
billyg
iron station nc
I found a craftsman 10mm male allen wrench looking socket at lowes that fit perfectly. I used a craftsman 3/8 allen style socket and ground it to the square shape and that worked for me. There are lots of answers to problems but the best answer is to avoid problems in the first place.
plumbstraight
georgia
Don't forget the grease zerts on the rear axle. for bearings on outboard ends both sides.
