Engine quits
jerry c
Southern IL
I have 12 hours on mime now. So far it has quit 2 times. The fuel pump shuts off. If it sets for a few min it will start and run fine. Has anybody seen this before?
TacoJon
Cheyenne, WY, USA
No but you should have a 2 year/12,000 mi warranty. Get her in stat!
Def sounds like lift pump.
Fuel pressure is a gauge high on my list.
Uncle Chuck
Mesa, AZ, USA
I have about 4500 miles on my 2019 ROXOR. I have found that occasionally, when I accelerate hard and for an extended time, the engine dies. (Think about accelerating onto the freeway.) If I turn the key off, then start it again, it will keep going. This doesn’t happen all the time. I live about 1/2 mile from the freeway and I suspect that this only happens when I get in and take off immediately and the engine is not quite up to operating temp. Doesn’t seem to happen if I’ve already driven a few miles.
Anybody got any ideas?
I have not had an issues with mine, wonder if it might be a dirty fuel pump
Uncle Chuck
Mesa, AZ, USA
Thanks guys! I’ll check it out. I have a scan gauge, but I don’t think it does fuel pressure.
They do but you might have to program your unit.
