While under there, check all the cotter keys in all the shift linkages to make sure they are in securly and bent over properly. Make sure your axle vents are up and tucked up high.
What did you figure out with the light? The light is just a simple 2 wire switch indicator on the parking brake. If the linkage is loose, check the switch itself. The button may just be stuck
