jerry c
Front and rear D ring mounts.
MAHINDRA ROXOR Heavy Duty Front and Rear D ring mounts with D rings. Condition is New. D ring mount is made from 1/2 in thick steel. Base plates are made from 1/4 in thick steel. D rings are rated at 4000 pounds. All mounting hardware is supplied.
Rear D ring mounts bolt direct to existing holes in the rear bumper. No drilling needed. Installation requires a 13mm wrench and 10 min time.
Front D ring mounts bolt direct to existing threaded holes in the frame. Installation requires 4 holes be drilled in the front bumper. Instructions included.
The D ring mounts you see here were designed for the Roxor. (The Roxor in the photos is mine) They may fit other vehicles, I don’t know.
If interested PM me $90.00 per pair. Let me know if you want a pair for front or rear.
I will ship anyplace, but buyer pays all shipping cost.
