Compshooter
- Joined
- Dec 14, 2018
- Messages
- 91
- Points
- 18
- Location
- Stroudsburg, PA, USA
- Roxor Ownership
- Roxor Owner
- Roxor #
- 0335
Here is a quick video to show you how to bypass the clutch switch. By doing this it allows you to start the Roxor from outside the vehicle without having to get in to press down the clutch. This is convenient for when you just want to get it started to allow it time to warm up. No more climbing in and out to start it.
You have to be careful though and make sure the brake is on and you're in neutral. If it's in gear while doing this the vehicle will lunge forward and cause injuries and possibly death if someone is in front of the vehicle.
I used a mini fuse to plug into the connector. This just allows current to flow through the wire tricking the computer to think the clutch has been pushed in.
