Broken rear hub.
Jefdry79
Norton Shores, MI, USA
I’m wondering if anyone knows if a rear hub from a tapered axle Dana 44 would work on the roxor? Mine broke at the keyway and ate the wheel bearing. I was able to locate a wheel bearing but having a hard time finding the hub. Any help is appreciated.
Maybe put a request out to someone who has replaced the rear axel with full floater and 30 spline kit. See if anyone has a extra OEM not being used.
I found one, on the rox had it. I still ordered the other o e to compare size to see if maybe it’s interchangeable.
I'm glad you were able to find parts. I'm curious how it broke?
Wheel chatter is the only thing I can think of, damn dude here in Michigan and I’m guilty of staying in it a little to king sometimes. Could be wrong but that my only guess.
???? I'm confused
I think he means wheel hop. spinning tires trying to grab traction causing wheel hop. Sudden traction is hard on parts.
???? I'm confused
Yeah sorry if that’s not the terminology your used to, it’s really sandy where I cruise in Michigan. Sometimes in two wheel drive if I’m hammering on it in the sand it will wheel hop like a mofo.
I just read my first response to you and it looked like I was totally loaded or something. Sorry about that I had just woke up and didn’t proofread......
I understood it. I guess that means I speak/understand fluid Ozzy Osborne?
wheelhop damages everything from the clutch to the rubber.
