Gene Trask
I changed my fuel filter. After changing it the roxor did not start as fast and easy as it always had.
I tried bleeding lines and checking my seal on the filter. Still the cranking was getting worse.
To the point now, it will not crank without a shot of starter in the breather. Hot or cold. Of course it runs great after cranked.
I took the fuel filter off to check again, and noticed that the electronics of the water fuel sensor were exposed to the fuel.
Would this be why it is not starting right?
