echo3delta
Has anyone considered putting on a water-methanol injection kit? I have a stage 2 tune from Gillomen innovations.
What are the benefits of Water/Methanol injection?
Greatly reduced EGTs - Decreases of 250 degrees F are common using a 50/50 water/methanol mix. Increased EGTs are an engine killer in today's performance diesel world.
Low cost power - Where else can you get 50-100 HP for as low as $549? What other modification does all these things with one system?
Greatly increased air charge densities - 3-5 psi boost increases are common with liquid intercooling.
Decreased emissions - increased combustion efficiency means less particulate matter and NOX emissions.
Fuel economy increase - increase your fuel economy up to 10%-15% (1-3 mpg).
Great for towing - more power/cooler EGT's to haul the heaviest loads.
