Road Shock LP6 for Headlights
Missouri Ozarks
I have been doing some reading to see if the Harbor Freight Road Shock 6-LED Lights could be used to replace the factory Roxor headlights. (In The Headlight Buckets) So far with no luck.
One would need to use the Harbor Freight Wiring Kit with Relay, and Switch I am sure. The lights have a Low Beam (2-LED) and a Hi-Beam (6-LED) Mode. This looks to be a good option if the Low Beam is not too bright for On-Road use. I have not seen a set used so far to know just how bright they would be. Everything I have seen so far is for Auxiliary Lighting, and not a Headlight replacement. From what I can tell they are impressive in Hi-Beam mode.
Don’t think they’re gonna fit. Look at the housing. Doesn’t look round. And i think the dimensions are slightly too large. Shows to be just over 7”. Maybe with some modifications you can get them to fit but why bother. Just get a light for a Jeep and plug and play.
