Power steering leak on new Roxor
Clevesi129
GA
I recently bought a 22 Roxor and after about 80 miles I noticed a power steering fluid leak. I checked the banjo nut on the bottom of the pump (22mm bolt I think) and it's super tight as is the 2 bolts that the plate that goes into the side of the pump from the hard line.
Are there any serviceable o-rings that I could possibly replace that could be defective causing the leak or should I just replaced the entire pump as it's only 60 or 70 bucks? Warranty is out of the question because it would cost five times as much to get it to/from the dealer as it would to just replace the pump myself.
Thanks!
Double check your hoses. Seems after the relaunch the power steering hoses deteriorated really quick and started leaking. I believe it was mainly the supply hose so it was an easy fix since you didn’t have to get one made With fittings.
Clevesi129
GA
Ah bad rubber, that's the best news I've heard all day. It sit at the dealership for 3 years so that makes sense. I appreciate the info m8! ~
