Duel Stick conversion Transfer case -Ready to drop in - Now available
GiStore
India
Thar Owner
Now available ready to dispatch brand new bench tested transfer case with duel stick for MT Roxor
No Core exchange required
Direct Drop in replacement transfer case
Some DIY efforts will be required to make provision for duel stick on the floor
* Open for 25% less offer for anyone willing to share honest feedback with details & pictures of conversion is most welcome- PM me for same
Feel free to touchbase with me for any further details
USMC
Naples Florida
Hello GIStore, were all the bearings upgraded when the transfer case was switched over to twin stick, or is it just the bearing cap and shift rod assemblies that were changed?
GiStore
India
Thar Owner
This is a brand new transfer case,With all new internal components including the bearings,You just have to take out the single shifter transfer case & replace it with this new unit
Yes provision for the duel shift sticks have to be made DIY on the floor
This makes the conversion minus the hassle of opening & doing hard work with the conversion kits,Its almost ready drop in TC & requires less mechanical skills to install.
Just the easy way out & gives you an opton of going back to single shifter as there is no core exchange.
Yes i also sell the conversion kit & open to add any more parts to the kit if required
USMC
Naples Florida
Maz, it appears that the Roxor uses the same transfer case for either transmission. You just need the transmission adapters to attach it to the automatic tranny if you do not have them.
DrunkenSlug
NC
How much trimming of the floor is required? Does it move the shifter and hi/low selector as well or just add 2wd/4wd stick to the side of the high/low range stick? Looks to be pretty simple if someone were to buy this.. I probably would have hopped on it but already added hub locks :(
GiStore
India
Thar Owner
Check the thread on the conversion done by some meambers for good insight on whre & how much of the floor opening is to be made
