Tire pressure
Tonopah
Peeples Valley, AZ
I have BFG M/T 33in tires on my roxor. I am currently running 22psi in all four with no issues. How low can I go before risking tire/bead separation? I'd like to try 18psi.
Tonopah
Peeples Valley, AZ
With the Bilstein shocks and 22psi the roxor rides so much better. I dropped the tires to 18psi just now and I will run it around the ranch tonight and see if that further improves the ride.
Nice. I would say not below 15psi, but I'm no expert, I'm still learning.
Did you do the shocks yourself ? I thought about upgrading.
Tonopah
Peeples Valley, AZ
My son-in-law did the shocks. I bought my roxor used and the prior owner did some kind of mild lift and adjusted the bump stops just a bit. The tires (255x85x16) do not rub at all. My son-in-law is a mechanic and he measured the spacing carefully and bought Bilsteins that fit my roxor right. By the way, the OEM shocks were absolute crap -- zero rebound and useless. So, in my case, it was easy to improve the ride!
