Things All Roxors need/ and things ive done thus far for engine performance enhancement
Clearfield, UT, USA
And here I thought Warn had the best hubs, I have MM. Far cheaper. So Max why are Warn not the best?
Max A.
Max A.
Baltimore, MD, USA
Warn
Vs
Mile Marker
Mile markers are built a little beefier. The drive ring is thicker and that’s what blows apart most of the time. They both have lifetime warranties. Why spend the extra money for the warn name.
Clearfield, UT, USA
Holy crap your right! Thanks max.
1BB
Church Point, LA, USA
WOW, that is quite a difference between MM and Warn. I've never seen MM lockouts before, but I have serviced countless front ends with Warn lockouts when I was a mechanic. I will say too, that I love MM hydraulic winches much more than Warn electric, or any electric winch. There's just no comparison if you're going to be using a winch, but if your winch is like a spare tire, just an insurance or emergency type of thing, then electric is more than fine, and there's no sense spending the extra money on hydraulic.
Max A.
Max A.
Baltimore, MD, USA
Warn’s customer service is what makes them legendary.
I’m running warn hubs but I also carry the stock slugs. Best to do that with any brand hub.
Max A.
Max A.
Baltimore, MD, USA
I don’t think mine will ever be an issue
Buckpasser
Buckpasser
Georgia
This is a great thread. The only thing I’ve done that I don’t see listed here is pretty simple but made a huge difference and a much more pleasurable vehicle.
When I got my Roxor I noticed it turned a lot like my old 2003 Silverado. I think it took six acres to measure the turn radius. The stops were adjusted stupid tight and when I got them just away from scrubbing it turns perfectly! I’d highly recommend looking at them if they are still factory set.
You need to search here for those who’ve done that. When you flex and turn you put the brake line banjo bolt on the caliper into the shock body. Best case you end up with a dented shock. Worst case you have a broken brake line and no brakes.
R
Roxor2360
Savannah georgia
Warn
Vs
Mile Marker
Max what is the mile marker part number for the roxor locking hubs
Cheech
Cheech
Daytona Beach, FL, USA
Warn
Vs
Mile Marker
Max, do you know the model number we need for the Roxor and also where is the best place to buy one.
Roxasuras (Chris) told me a couple months ago I benefit from them as spend all of my time on local roads and on the beach.
Thanks Brother..
Buckpasser
Buckpasser
Georgia
I’ll check it out.
Tonopah
Tonopah
Kirkland, AZ
On mine, I guess I am going all out. It has been sitting at AZ Differential for months waiting on parts and since the Roxor is apart in pieces, I can't take it to my son-in-law's shop to have the other work done even though those parts are in.
Waiting for parts for:
lockers front and rear (ox cable, levers)
cromoly axle shafts
Parts are in for:
heater
electric fan
turbo intake fix
