Suspension
Lwhite5
Savannah, MO, USA
Needing some help to stop my suspension from squeaking. I have greased all the grease certs, raised the whole thing using a bumper jack and sprayed down all the bushing and pads with spray grease and PB blaster. I even went through and checked all suspension comments to make sure everything was tight, but it still squeaks. I have 2100 miles on it. Any advice?
Collin S.
Fallbrook, CA, USA
Hey man I have the same issue. I’ve done everything to stop it from squeezing too. I think we have to just get used to it lol.
Max A.
Baltimore, MD, USA
Make sure the u bolts on the axle are tight.
b-pinkerton
I’ve had the same problem. While I have not been able to make it go away completely, I have been able to make it temporarily go away using a silicone lubricant spray. My problem has been when I used WD-40, it would get dirt and dust caked on. Then it would squeak worse than before. The silicone lubricant seems to be the trick I’ve found yet. Hopping for a more permanent solution though.
I use my Roxor for hunting and I hate driving around the ranch sounding like a squeaky siren!
