Stuck in low, help
Roxor76028
Burleson, TX, USA
Recently purchased a 2018 Roxor with 250 miles on it. Previous owner never used low range. While test driving noticed it would slip easy into 4 High, but 4 Low was near impossible. Did eventually get it into 4x4 low & back out but it was extremely hard.
Once home, read the forums & found this is normal so figured I'd work it a bit. Shifted into 4x4 Low now its stuck. Won't shift out. Tried all the tips & tricks; clutch out , rolling forward, rolling backwards on slight incline, etc. Any ideas?
Much thanks in advanced.
Try pushing it down and then up. It should eventually go. Natural and letting it roll to a settle position usually does it.
