Running 33s tires on bone stock Roxor
D
Deuskid
St Louis MO
Thanks,
What is your tire size and about how much is the tire outside of the back wheel well? I can see from the pic in post 11 you don't have flares.
S
Siriustock
St Charles, MI, USA
I’m running 33x15x12.5 with just the climax 1 1/2in front shackle lift.
Thanks,
I had no flares in that pic. They’re 33-12.50s. I have flares now and I think they stick out about an inch.
W
Wm435
Fort Myers, FL, USA
I’m running 33x15x12.5 with just the climax 1 1/2in front shackle lift. View attachment 9549
I got 33s in my garage, and awaiting for my shackles to come in from diesel freak. I will be running the same set up as you. Did you have to adjust your steering stop or anything?
Don’t adjust your steering stops. If you open them up to turn better than your also opening up yourself to hitting the brake caliper banjo bolt on the shock during articulation. best case you get a dented shock body, worst case it busts that banjo fitting and you lose all brake fluid and brakes.
W
Wm435
Fort Myers, FL, USA
Thank you for the heads up. I will be certain not to do such a thing.
S
Siriustock
St Charles, MI, USA
No I didn’t adjust anything. I got the rims and tires from Wade at Diesel Freaks so they had the correct back spacing for the tire size.
