Rough Country kit installed
928dennis
Cassville MO USA
Just finished this kit up, It is day and night better then the stock setup with a Add A Leaf. The ride is much improved, and I gained almost a 11/2" more travel ,now I did some research for front shocks, I come up with a KYB part that will work with a stock setup also. It is a Gas adjust unit # KG 5473. It has almost the same compresses hight and extened lenght about 3/4" longer then the stock shock. I bought a pair from shock Warehouses for 77.00 a pair shipped.the stock units are junk. I will check on a rear part# soon.
AZROX
Phoenix, AZ, USA
What is the diameter of these shocks? Is it the same as the stock shocks?
Earlier on this forum, someone posted another shock that fits for length. However, since that shock had a larger diameter than the stock one, it could only be mounted upside down.
Thanks for your updates.
